Little Bear T7 Replacement Adapter
calexcyou
Member
hi, not sure where should place this, but i have a Little Bear T7 Tube phono preamp, and in the process of moving i lost the power adapter.
i cant find one anywhere. The manufacturer is in China , and take a couple of months to get here in the usa.
does anybody know where i can find one ? or just find a generic one. Specs are : Model # PP141-A12V600. Input - AC115V 60 Hz . Output : AC 12V 600 Ma
thanks
alex
No affiliation but search amazon dot com. They will have what you are looking for.
12 volt at 600 milliamp is fairly common.
Amazon is where I've bought a few. It should be easy enough to find one.
Going up in current output is fine also. I amp would work just fine.
I recently bought one that had a 1.5 amp AC output from Amazon.
If it's AC output like you posted originally, then it must be AC output, not DC output like those two you just posted.
Let me dig up the one I bought.
Go to Amazon and look for the JAMECO RELIAPRO ADU120150E1012
AC-AC wall adaptor transformer, 12v @1500ma output.
That will give you 1.5A output. They're around $14
The original is 600ma. That's .6 amps. Getting one thst can supply a higher current like the 1500ma one,(1.5A), I posted will work just fine. The Little Bear will only draw the current needed. The wall wart won't "push" the whole 1500ma to the Little Bear. The Little Bear will only draw what's needed from it. Have a transformer that can supply more current than what's needed isn't a bad thing.
It looks like this one will work however, just make sure your input plug is the same as the new one (2.5mm).
True, most if not all these lower powered Chinese phono preamps and such use the 2.5mm plug. I haven't run a ross one yet that didn't.
I almost ordered a new one a few days ago. I couldn't find the one for an Orbit turntable. I found it behind the turntable with the cord wrapped around the wall wart. Not in the bin where I usually keep them when not being used.
