Refresh an old thread!
I've had my L.B. V2.2 for a few months now.. Out of the box, its really sweet! The first tube for sure is your interference probe! That can be fixed, etc...
For some reason, I don't like the 6z4, so, like most stuff, I love to mod! And I did here too!
I built my own outboard 6ca4! Using a spare 120v -> 6.3v I had laying around... all is perfect! The 6ca4 is overkill for the L.B. but I don't care, lol.. I just wanted something different, and better quality then the China 6z4.. Well, ok.. I wanted a bigger rectifier tube since the 6n2's where larger!
I ran the power from from the pins of the 6ca4, into one side of the 200-0-200 spot on the board.. Then I jumper'ed the old 6z4 socket to 'bypass' as it were so I could revert if I felt the need to down the road.
Still a 'slight' hum when you crank the volume on your source, headphone, etc.. BUT!!! not bad at all, and I haven't done anything else to help fix that.. aside from twisting the power wires, etc.. I'll build a shield on the first tube soon..
I also have a double sided copper PCB (as big as the LB board) below the main board to to help with noise, etc... My record player doesn't have a ground, so I've got the earth ground, and the board grounded to the copper plate PCB.. That really killed the hum I had when I first did a dry run..
I have a Music Hall USB-1 with an Ortofon 2M Red and I found that 47k input helped a lot, and it seems to be the common opinion on the net.
