bikingbuddha
Well-Known Member
From a hand full of reviews I read, there was only a minimal amount of hum at high volume. Does it make noise with nothing plugged into it but headphones, and with everything you had plugged into it turned off and disconnected? Did you try setting the dip switches inside to better match your headphone impedance?
Alright... let me be a little clear on this. Sorry if I got you lost and confused!
Gain stage 1 (lowest) - No noise on HD-6XX, others there is noise but very minimal (Not a hiss) (others are iem's and monk plus)
Gain stage 2 - No Noise on HD-6XX until I pass the 80% at least on maximum volume (very minimal). Others have the noise all over the volume range
Gains stage 3 - No noise on HD-6XX until i pass the 70% to 80% Mark (Minimal). Noise in all others (Lower impedance and iems)
Gain stage 4 (Highest Gain settings recommended for High impedance headphones) - Noise all over the volume range even on HD-6XX
* This noise goes up and down with volume controller.
* This noise is there regardless of what is plugged or not...!! just the amp connected to a completely isolated powerline even outside the house next to the main power board meter. The noise is there.
