MunchsUncle
This charcoal grill was purchased at Walmart a couple of years ago. It had been out in the weather for the entire time it had been out of the box and assembled. I had to change my diet by putting in fish and chicken and removing the beef by and large. Make up you own jokes. I had my towing guy, James Sullivan, General Towing, cut the notch for the pan handle with a grinder. He cut the notch for free. You can put wet wood in the bottom of the pan under the grill that holds up the charcoal from below, I suppose, but I never did. Just spray the pan on both sides with any cooking oil. Here is the list of stuff with which to make the apparatus. This will grill two swordfish fillets with no skill required. The total cost to me for all of it was $27.00.
Use the legs on the grill at your own risk. I do not recommend putting the grill on the legs with burning charcoal in the grill for obvious reasons. Those legs will fold up under the grill, but remove the plastic foot covers off the feet on the legs. Those feet will melt and affect the quality of the experience. The grill has a skirt on the bottom and all you have to do is just put the grill on the concrete, or asphalt. Be careful and use a mitt to hold the handle on the pan, because it will be very hot. When the fish is done, it should slide off the pan onto the plate, so don't drop the fish off the plate. Spray the grill with Pam Grill Spray and spray the pan on both sides with Pam Butter Spray. Pour drawn butter over the fish with spices and lemon in the drawn butter. If you cook the fish until it is done and flaky and juicy, the oils and the butter will create a flavor.
UniFlame 138 sq inch 14.5 inch in diameter Portable Charcoal Grill: www.walmart.com ~ $15.00
Grill by HD Designs 12" grill skillet: Kroger: $9.75; or www.MCMElectronics.com ~ Grand Rapids Industrial Products Non-stick 12" grill skillet Part # 22-15903: $12.99
1.25 inch by 1.5 inch notch in the grill lid.
