This thread is to document the restore of my EPI M400 speakers. The is going to be a bit of a "resto-mod" with a replacement of the crossover and all drivers with new ones from human speakers.
Why new drivers, you ask? Well, three of the woofers are blown and I know how good the new drivers from human are since I restored a pair of M100's using human's drivers. The new tweeters have more extension and are smoother than the 40 year old original tweeters.
Does this make sense financially? No. But a full driver & crossover replacement will cost as much as a pair of new Wharfedale Linton's or KLH Model 5's. And I'm a fan of the EPI house sound, so why not (don't answer that, it's a rhetorical question, LOL).
Specs on the original M400's:
Dimensions: 38" x 14" x 14"
Weight: 90 lbs
Response: 28 to 18k Hz
RMS Power: 30 to 200 watts (conservative rating)
Impedance: 8 ohms
MSRP: 800.00
Built: 1973
Yep, these are 90lbs each. Heavy MDF cabinets with bracing on the inside and walnut and brass on the outside. Even though 3 out of 8 woofers were blown, they put still out out excellent, tight, bass.
EPI glued the 4 grills on from the factory and there's a lot of old glue to remove. There are also a lot of brads on the face of the MDF that need to be hammered flat. My plan is to sink all the brads, fill all holes with putty, sand the faces smooth, and repaint the faces satin black. The grills will be reattached with velcro.
This is probably going to take me a month to get both cabinet faces all prepped and painted.
The walnut veneer is in decent shape. There's no loose veneer, but it has a lot of minor wear, tear, and scratches from 40 years of use. My plan is to use steel wool to apply Restore A Finish, and top it with wax. I'm not going for a 100% perfect veneer restore. A bit of patina is kind of cool.
Here's the start of the disassembly and prep work.
Bonus operational woofer looking for a walk at the end of pics below!
Weight: 90 lbs
Impedance: 8 ohms
MSRP: 800.00
Built: 1973
