For me its all about the speakers you buy. The sophistication of the crossover, and they whether the box is sealed or not depends on the impedance of the speaker at any frequency. The more complex everything is you have to depend on the speaker designer to get the damping of the speaker correct. The more complex the speaker also the more the chance the speaker loading will efect the over all response of the amplifier. Take a 275 for instance. A crossover can make the response of the amp almost vary 5 to 6 db. So thats why it was so important to match amps to speakers in the old days. Where if you look at a Direct coupled Crown or Accuphase with the same speaker the vaiance would be less tan a half of a DB by the amplifier due to speaker loading. Well the Autoformer amps with damping over 40 the issue is almost not an issue anymore. Especially when using speakers with passive crossovers. Now if you were bi-amping with out the use of passive crossovers and using electronic crossovers with separate amps for LF and HF yes there would be a big difference between a 275 with a rating of 16 and say a a MC 7200, 6200 or modern direct coupled amps. The woofer is connected directly to the amp so there is more control on the woofer and because the HP section is also removed from the HF speaker there is more control there, too. But is to much control a good thing. Well, if a speaker is all ready critically damped like a ML-1 or XR-5 then it doesn't make any difference in most cases as far as woofer control goes, but you can have still have frequency response issues with low damping amps. Mac speakers have very consistent impedances. It doesn't make amps with autoformers always better, though the design can relieve strain on out put transistors. But if the amp is over designed like the 7100 and 7200 were to specifically drive certin speakers there is no issue either. The autoformer does introduce a penality. Lets say your speaker is a paneled speaker and the impedance is 85% over most of the range . But in the bass and top octave it drops down to or below two ohms. Well if your current Mac amp doesn't have the current reserves or necessary heatsink cooling your amp will shut down. Making you choose two ohm tap. But that penalizes you 6 db in power to the 85% of the spectrum that is near or above 8 ohms. Well if you have enough power at 2 ohm tap you are OK, but what if you need the extra 6 db you have lost. TILT. You need a direct coupled amp that has the necessary current capability. Well in the age of the 2000 series amps, 2105 2125 2205 2255 etc. They didn't have the current capability the newer amps have. A MC 501 will put out over 700 watts driving a 4 ohm load from the 8 ohm tap. So you are not penalized today like you were in the past. N0t that capability comes with a penality. The old amps would run all day and all night at full power. When the new amps driving a mis matched load will over heat and the sentry monitor will kick in shutting the amp down. But there is an easy solution. But an unit with more power than you need for 90% of your applications and let the power guard take care of the rest. This is where experience comes in. If you are running Mac speaker designed by Roger Russell his power ratings could be straight forward. Now days they give peak ratings most of the time. So in Rogers case he said 1000 watts for an XR 290, you bought a MC 2500 or a MC 1000. Today you know a Mac amp will typically put out 30 % more power than rated when the power guard clicks on and thats is the power you buy for your speaker less 3 db. The peak capability of the amps gives you that back before the power guard starts triming thing back. So today you would buy a 611 power amp for 290's to be safe as it puts out close to 900 watt peaks. . If you want to live on the wild side you buy a 1.2 K and hope the 1600 watt capability doesn't damage the speakers. For replacement drivers might not be available any more. But then no one listens at 120 db levels! 104 peaks is about all I can take any more. But if you like to feel your bones rattle at 43 hz go for it.
So the question is a 5300 enough. I would want speakers with at least 94 db efficiency. If you are less than that then you have to decide whether your music choices and room size will allow you to be happy. Remember most people seldom go over 90 db. Throw in 10 db for distance and 6 db for peaks thats 107 db. One system I have I can reach that with 40 watts. The other takes 120 watts. I have 240 watts per channel so I am fine. But I still want to MC 830's = 480 watts 4 ohms or almost 600 watts peaks for sure.
