sooner8888
I would like to crossover/high-pass my mains so they are spared frequency demands of 80Hz or so and lower. It would be a bonus to also prevent the power amp from being asked to deal with the demand of these lower frequencies.
Currently...
I have a pair of KEF passive LS50s, and a pair of SVS SB12-NSD powered subs. My system includes a Schiit Freya+ preamp with one pair of RCA outputs feeding the subs directly, another pair of XLR outputs feeds an Anthem power amp which feeds the LS50s.
I want to limit the full range signal to the LS50s, and let the subs handle all the bass.
I could route the signal from preamp to subs, then to power amp, then LS50s, and use the sub's active crossovers to highpass the power amp/LS50s. However, since the subs are RCA only, I cannot use the XLR outputs from pre. Freya+ has passive, JFET buffered and tube buffered modes. I use the JFET mode for most of my casual listening to extend the tubes' life, and Freya+ performs noticably better in JFET with balanced connections, so I'd prefer to use balanced XLR outputs from pre.
What to do?
Are there audiophile-ish quality active crossover I can route everything through, and incorporates balanced XLR? Bass blockers?
I thought about miniDSP with XLR, but as I often do my critical listening though Schiit Sol turntable, it doesn't make since to me to convert analog to digital and then back to analog. Am I overthinking this solution, or overly concerned about degradation of the analog sound quality with all the signal conversions?
I've considered pro audio solutions, like the dbx DriveRack, but these can be noisy, and lots of extra circuitry for the signal to pass through getting "dirty" all the way.
Setup...https://imgur.com/a/UrdCv75
Currently...
What to do?
