A little update on the spiders.
Since I know I will have to replace these I will first make a few experiments.
I took the speakers apart again and started treating the spiders with the least aggressive method.
Applying water and using a hairdryer on high heat while rotating the woofer on my spin table.
Already after the first application the spider retracted back. But as Gordon mentioned earlier the “oil canning effect” is there. The stretch of the folds in the spider has produced excessive material. Therefore the spider becomes a little concave or uneven.
I have made 5 applications over the last 5 days. And the spiders have leveled out quite a bit.
See picture of the spiders before and after. Also, both woofers next to each other
the surround before: sagged outside the gasket.
and after: in level with the basket.
I will mount the woofers back into the cabinets and see how long they will stay this way. When I push the cone outwards now it retracts to a normal position so there is a new position memory in the spiders. The surrounds seem to be in a flat line how I would think they were as new.
My next step I will try a chemical of some sorts. I will update here as I get to it.
Two more photos from today of both spiders.
