telecowboy
I have been experiencing a bad, loud, and variable noise in my electric guitar rig. Here is the details of the rig (I will include as many details as possible since ground loops are tricky):
> Electric Guitar (active electric guitar with on-board buffer, 9V battery, and On-Board Effects Loop (two output cables, mono and TRS, which creates a loop for the guitar signal to bypass the effects chain from the guitar, not sure if this can contribute to the ground loop)
> Pedalboard (a few pedals run through the buffer box for OBEL, all powered by a high quality isolated power supply. The power supply uses a grounded, 3-prong power cable.)
> 1/4" mono cable to TUBE GUITAR PREAMPLIFIER (powered by grounded, 3-prong power cable, with a 1/4" preamp out jack to poweramp)
> 1/4" unbalanced to male RCA to poweramp
> McIntosh MC50 power amp (powered by original unpolarized 2-prong power cable, orientated at the correct polarity for least noise and chassis voltage)
> Banana Spade Adaptors on C and 8ohm terminals, running banana plugs to 8ohm JBL speaker
* All three power supplies (two grounded 3-prongs and one 2-prong unpolarized, are all plugged into the same Furman power strip that is plugged into one outlet. Therefore, I would assume I have a ground. I also think the Mcintosh uses the preamplifier's safety ground when I have them plugged into each other, correct? Is there any concern for ground loop due to this setup?)
A few points I've found in my troubleshooting:
- The noise gets louder and louder the more I turn up the gain on the Mcintosh power amp. Just past zero it isn't noticeable but as I approach 11 o'clock it gets very noticeable. I play it around 1-2 o'clock so it's an issue.
- The connections between preamp and poweramp don't see to change the noise when moved around
- The preamp gain and many of the knobs such as gain, output gain, treble, reverb, all add to the noise the more it is turned up.
- If I unplug the preamp and run the Mcintosh into the speaker, there isn't really any noise. This leads me to believe the noise is generated downstream from the poweramp.
- If I mute the guitar at the pedalboard, turn down the volume on the guitar, or unplug the guitar, the noise is still present. This leads me to believe the noise is generated upstream from the pedalboard and guitar.
I don't know much about vintage audio and the Mcintosh is my only two-prong piece of equipment. Does it sound like I've introduced a ground loop from connecting the different amps, or does this sound like an issue of a noisey tube amplifier that is sending noise upstream to the power amp and speaker? Thanks!
