Natertots
Well-Known Member
When it comes to buying replacement tweeters should I try to find an original set? I saw some on ebay that seem to be newly made reproductions. Would they sound as good as the originals? I'm assuming I have to replace both of them at the same time?
No reason to replace both tweeters if the other is fine. I would look to buy single original driver. If you don’t buy a vintage peerless, then you would want to replace them both.
I suspect RTally is right, posting a thread in the speaker forum about refurbishing them will likely garner more responses and advice on the process and driver possibilities. Best of luck.
