Do you have the board removed from the heat sink? If so, give all the solder joints a good look under bright light and magnification for lifted traces (may not be obvious if there’s a large solder blob), bad joints (sometimes identified by what looks like a crack in the solder in a ring shape), and other signs of abuse...darkened areas, etc. especially look at the drivers (mounted to smaller heat sinks) .
