Looking for some ear pads
I have an old set of the original Koss Pro 4A headphones that I'd like to use sometimes. No surprise the original ear pads are shot.
Looking around I've not found a source for them. Does anyone know if the pads for the later 4AA or 4AAA models will work, or can you suggest an alternative?
Originality is not a concern, just so they work. Plus these aren't worth a ton of money so I don't want to spend more than they're worth on the replacement pads.
Thanks.
Dave in still too damned cold Iowa
Thanks.
Your best bet is to carefully remove the original pads and take measurements - pay close attention to how they are attached to the earcups. There are plenty of headphone pads on amazon, and usually in addition to the 'fits models:' description they also put in mm measurements. You may want to just try a set of pads for the 4AA from a place that accepts returns - look to see if the pads for the 4AA and 4AAA are the same size, and if in the description it gives mm measurements similar to your own. Brands I've had good experience with: Brainwavz, Uxcell, EarZonk
If you do find the correct fit, please make sure to give details here in your thread for future owners of the 4A to find.
Good luck !
I've found Koss to be very helpful whenever I have called them. They may not produce the actual replacement anymore but I bet if you sent them your 4a's you'd get them back with new cushions that they were able to retro fit.
