Meg_K
Hi, all. This is my first post and I'm really hoping someone can help me.
My old, terrible turntable died and I ordered a Realistic LAB 300 from eBay to replace it.
It arrived today, so I set it up and it sounded great. Maybe a touch slow, but otherwise a HUGE improvement over the turntable that I am replacing.
But after a while (maybe 30 minutes or so of playback) the sound started to become distorted. I also noticed that the surface of the turntable had become noticeably warm to the touch (which might not be a problem, but seemed strange after such a short time).
To my ear, the distortion sounds like a radio losing a station’s signal. There is no noise when the needle is in the up position, but when the record is playing there is this crunchy, staticky distortion that is completely unlistenable. Again, this only began after playing records for a while. It was a dramatic deterioration from when I first set it up.
I tried several different records and had the same issue with each of them. And just to make sure it was a problem with the turntable -- and not another component or my speakers --I switched the receiver over to FM radio. Sounded great.
I checked the owner's manual and didn't see anything in the instructions that seemed directly related to this problem. (I haven't found a service manual for this model.)
It sounded so good for the first half hour that I really want to get it up and running rather than trying to return it to the seller. My forum lurking leads me to believe that some kind of cleaning/lubrication regimen might be the way to go. (And maybe a new belt, too.)
The fact that the sound began to suffer after running for a while makes me thing that there could be some old cruddy lubricant in there that warmed up with use and started really gumming things up. Does that seem likely?
I am a turntable newbie, but I have some experience and a fair level of comfort working on audio gear. I would like to do the most efficient amount of work possible for the best possible result, and I will bust out the soldering gear if I have to.
To recap: there are two, possibly three, concerns with my new-to-me LAB 300:
- Slightly slow speed
- Very warm after short duration of use
- Noisy playback
