Looking for expert advice on mating a Westerm Electric 594 to an Altec 1505.
i was under the impression that this had been done before and although i know it isn't ideal has anyone done this or know someone who was done this or should i abandon the concept?
I have a 594 due to luck. It came with a 31A so in an attempt to upgrade while i dream of a 24A or 26A horn i purchased a 1505. While i knew there was the obvious issues around bolting and throat attachments going from 2" to 1.4" i had thought in all my research i had read examples of this being a viable option. Sadly i can't find actual evidence now and am just confused.
This could apply to any 2"exit into 1505 i imagine. Is this just never going to sound good or ever apply the correct loading to the driver?
The easiest functional solution i thought was to get a Eminence HA14-2 1.4" - 2.0" Compression Driver Throat Adapter and attach to a trad altec throat. What i wonder is if someone has designed and produced a small run solution for this problem. Is there any known 2" to 1505 horn throats that have the proper taper etc... or is this just always going to be wrong?
I appreciate any and all insight.
