Hi All –
I’m interested in buying a record cleaning machine. I have about a 100 record collection, many of them old records of mine that I abused in high school and no longer sound very good.
I don’t want spend more than $200, and I gather that the main advantage going over that price is easy of use and efficiency rather than cleaner (or much cleaner) records.
I’ve read up on the main contenders in that category and am leaning toward the Record Doctor V, which sells for $200 at audioadvisor. It seems that this is basically a Nitty Gritty 1, (on board vacuum and manual rotation), but a lot cheaper, no?
I happen to have am unused Jensen turntable in my closet, so I though I could keep things cleaner by using that to clean one dirty side of each record, before moving it over to the Record Doctor.
I’d appreciate any thoughts on whether this is the best choice. Other contenders include:
- KAB EV-1 – sells for $170. Seems to be like the Record Doctor, but you attach your home vacuum cleaner. Apparently has a much better platter than the Record Doctor, which makes it easier to spin the record. But it seems I can also just buy that separately for $15 and attach it to the Record Doctor.
I’m wondering whether having to use my home vac is actually a good feature, in that the unit is less likely to ever require repair.
- PHK NANO MECO – from Brazil. $190. Also uses the home vac, but with a built-in motor, unlike the above options. Has some good reviews online. Maybe this is a good way to go? Or is does this just leave me with more that could break and be hard to repair?
- VINYL MAGICIAN – Don’t see any on ebay and don't know if this is still being sold but it seems similar to the Nano Meco, but requires a shop vac. It’s a no-touch system (not sure if PHK’s is also).
-OTHER affordable DIY options for sale? (I know there’s a big thread on this, but that thread is almost overwhelming, and I'm looking to buy rather than build)
Any insights will be much appreciated!
Thanks!
Alex
Thanks!
Alex
