Lost Use of EQ after Tape hook-up
Myvinyl333
I hooked up a TASCAM 122 MKII Cassette Deck to a Harmon Kardon hk 670 in Tape 1 and a CDP in to AUX. TT in Phono. But now no EQ. I was going form EQ out of tape 1 to in of EQ...out of EQ to tape in of 2. I am not sure where I went wrong...
out of tape1 and in to tape 2 is wrong - doesn't your EQ have a tape loop ? If so then tape1 out to EQ, EQ out to tape 1 in - and tape conected to tape loop on EQ
Press tape 1 on receiver to obtain EQ
A cheap Techniques Ebay 7 Channel purchase. I am looking for a better EQ as we speak.
jorge
While you're looking for a better one, unless you REALLY need to EQ - due to some other problem?? - just take the EQ out and rehook as it was. Pass it on to Good Will or other, where a buyer can see & evaluate it before purchase. This presumes it didn't cost you too much & you need to recover some of the dough
DeadHead Ed
The ideal setup would be to connect the deck to the tape out/in loop on the back of the Technics Eq, just like jan_stenvs said: Starting again, go from the HK's "Tape 1 rec out" to EQ's "line in" then from EQ's "line out" to HK's "Tape 1 playback". The the Tascam's output goes to the EQ's "Tape playback" and the EQ's "Tape recout" go to the Tascam's input. Keep the "tape monitor" switch in on the HK and use the "Tape monitor" button on the EQ to engage the cassette deck for Playback. I hope this helps.
