Figit090
Member
I would try without heat first, only for fear of being too aggressive and taking the laminate with it.
OOOO GOOD POINT. lol...that was definitely an oversight, thank you!
Just a comment about the seller saying they aren't in a hurry or things aren't going anywhere.....they probably failed to mention how easily they could change that tune. If you have the desire and some coin, I suggest you strike while the discussion is fresh.
Indeed! I have been ruminating on this for a few weeks and that's part of why I made the thread, I was getting anxious the deal may change/expire. If I don't figure it out someone else might do so first! I've tentatively arranged to go see the stuff in a couple weeks, I will offer asap.
I'd want one of those SOTAs the most.
They were commonly paired with Sumiko MMT tonearms when they were new.
Modern equivalent is now sold by Jelco (who actually made the MMT)
Great info, thank you! Did I get the names right with the vacuum bit? Do you know if that vac pump was also the power source? I have no idea how reliable/expensive to repair it might be but I hope it all works! I can't tell for sure but I see something sticking up where the tonearm should be so the vacuum model may still have the tonearm.
