SCAPE_GOAT
Will do!You might consider letting folks know where you are located.
There could be someone near you that could help you out.
Were a friendly bunch ya know.
Ha, I’ll keep that in mind!And I must say that some of us, and not mentioning any names, are a bit 'obsessed' with the collecting of stereo gear and
therefore should be avoided.![]()
That rings alarm bells for me....the GND post on my receiver (an SX- 580) is rusty.
I suspect the problem is inside the amp. The rusty connector isn't making contact with the chassis and the 0V line it's supposed to be connected to.I missed that first read around.
Def. clean that post off. Wire brush or steel wool.
Good catch rothwellaudio.
If the problem is with the amp, can I expect that cleaning the rust off will be the fix? Or is this something I’ll have to dig around inside the amp to deal with? I hope not, I’m still a total novice with this stuff.I suspect the problem is inside the amp. The rusty connector isn't making contact with the chassis and the 0V line it's supposed to be connected to.
Will definitely be replacing the RCAs if simply cleaning the rust doesn’t work out.If the RCA's are detachable try replacing with different one's. If not, clean the RCA's , cartridge connections and head shell connections with contact cleaner. Make sure that all are firmly connected. Make sure cartridge connections are correct. Keep the turntable as far away from any digital appliances/gear as you can.
I'm only guessing that's the problem, but if it is it will require some work internal to the amp. I doubt cleaning rust off the outside will fix it. I could be wrong though.If the problem is with the amp, can I expect that cleaning the rust off will be the fix? Or is this something I’ll have to dig around inside the amp to deal with? I hope not, I’m still a total novice with this stuff.
