CDinMB
Just received my "excellent condition" flea-bay MC 30s. I love them with the La Scalas but they are a bit less than excellent, besides the two DoA tubes when I start them one generates a VERY loud pop through the speaker about 10 seconds into the warm up. No pops, static or cycling after that. I checked the plate voltage at start up and it peaks at 447v just before the pop and then drops to 426v where it stays. Wall voltage is 121v and plate is 426v. At 115v variac line voltage the plate is 405v. The amp sounds great after the warm up but I am afraid it will hurt my speaker every time I turn it on. Volume control has no effect.
My theory is it is high voltage arcing due to the higher voltage before music starts flowing and tubes are heating up. A component is breaking down and is probably marginal but working in steady state. I have pulled and cleaned all the tubes, pins, and sockets, swapped tubes, and checked for black arcing traces inside and out. Found nothing obvious.
Any ideas for simple things to check before I start to unsolder and replace components? TIA
Carmen
Carmen
