Ive been re capping a Marantz 2265 as well as installing the sparkos labs op amp on the pre amp board PE01.
I had only been getting sound out of one channel after doing the pre amp board but found the mistake was a reversed polarity capacitor at position CE13 ( I know rookie mistake).
Since then I have sound from both channels but the speaker relay will click and my DBT will flash when I press the loudness button or turn the bass knob to about 2 oclock position.
If I turn the button off or the bass knob back to 12 oclock speakers re engage.
Additionally I have been hearing a hum that is only present with audio and gets louder when the bass knob is turned up.
So main problem
Speaker relays disengage and DBT lights up when loudness is pressed or bass knob is turned.
- I have checked the DC voltage on the power supply board and its spec at 35
- Right and Left channel amp DC offset and idle current are set to spec
- I checked the pre amp and power supply boards for cold joints or burnt components and dont see anything obvious.( Im new to this though so my eye isn't great)
- I used the pre out on my marantz 2252 to the main in on 2265 and was able to manipulate loudness and bass without issue.
- So I assume this narrows my problem down to the pre amp or power supply board Im just not sure what to do next.
- The humming noise is also not evident when using the pre out from my 2252.
Appreciate any help!
So main problem
