Loudness button: what's it REALLY good for?
I forgot to mention my Kenwood KR-9400 AND KR-9600 both have 2 stage loudness switches, unique to only those. I like having that range for the very broad taste of music I listen to:)
I only use it for very low level listening usually at close range for instance in an office situation where you can't, out of respect for others in the next office/cube, have the sound up past low background levels, where the bass just disappears.
Loudness is used to compensate for small and-or cheap speakers. Full range flat response speakers don't need loudness, even at low levels.
Sorry, but I disagree. Loudness is designed to compensate for how our ears perceive different frequencies at low volumes - regardless of speakers. Loudness attempts to compensate for the Fletcher-Munson curve.
I find loudness adds greatly to low-volume listening (e.g. late nights when the family is asleep).
Alberto
No loudness for me, ever. I am a minimalist as much as possible with my audio. Just my opinion, however.
I'm pretty sure loudness comp. was around way before Yamaha and Mc were popular--- My guess is that it first surfaced in '50s HK, Scott, and Fisher gear.
About the Kenwoods... My ka-8100 has 3 stage loudness and also 50hz/100hz selection. Neat, but I leave it OFF
In my younger days, I would use it to get some boom-boom to the bass, but now I never use loudness compensation. Either my pre-amps don't have it, of if they do the tone controls are by-passed. And quite frankly, I don't miss it.
Like previously stated, it's main intent was to "boost" bass at low volume levels.
Unfortunately, from what I've seen in the real world, I have yet to come across a receiver that rolls off the bass boost at higher volume levels. Thus making the "loud" button into nothing more than just another form of bass eq. And also from what I've seen, most "loud" functions tend to be much more than just a small boost, and tend to be wider in spectrum than is needed.
On the other hand- many car receivers have "loud" functions that work too well. For instance, my stock Ford head unit has a loud function that you can not turn on nor off, and it is too exaggerated. At low volumes, it really pumps up the bass to compensate for how our ears work and for road noise. At high levels, it rolls the bass back to flat or perhaps even to negative levels. During use, peak bass levels are actually only attained at one quarter volume or less (!!), while the mid and treble frequencies operate normally, getting gradually louder as you turn the dial higher.
when i was a kid .
i used the loudness button
prodigiously.
along with the bass boosted separatly.
i had a pair of klhs(80s) with four 8 or 6 inch woofers.
talk about bass. cleans your ears while your at it.
they had a high damping despite being ported.
they didnt really need it(boost)
but hey i was young. and they took everything i threw at them.
Alberto
My infinity IRS Sigma are flat to 28 hz, and positioned for best bass response. Bass i very clean and tight, even at very low levels. I don't see the need for more bass which alters the recording. Of course if you are a basshead you can't keep your fingers off..:nono:
Who was first with the Loudness Compensation control? Yamaha or McIntosh?
Probably neither; it was moderately common in the early days of consumer/hobbyist hifi. For example, the EICO HF-52 had it in the mid/late 1950s. My Sherwood S-5500II integrated amp (probably early-1960s vintage) had variable loudness as well.
I never use my loudness button on my Pioneer SX-1250. My Yamaha CR-2040 I always use it. Yamaha had the right idea making it variable instead of full on like the Pioneer.
Alberto
My C504 as with many Mac pre's, has variable loudness that works the reverse of a Yammy where flat is the max clockwise position so that it can be used as a volume control once you set the real volume to your liking. The Mac is flat at the counterclockwise position and provides a Fletcher-Munson boost as you turn clockwise.
Most of the time I play FM at low volume so I will set the loudness at no more than 1/4 of a turn, and it sounds great like that. When doing "critical listening" at higher volume I set all tone and loudness off, which in my case is like a tone defeat.
VARIABLE IS MUCH BETTER!!!:yes:
Just to set the record straight: actually the "on-off" loudness switches do impart a variable contour... the degree of LF and/or HF compensation (typically it's actually MR suppression) is a function of the setting of the volume control. The problem is that the SPL in your room (which is essentially the important variable for the Fletcher-Munson curves) as a function of where the volume control knob is set depends on many things, not the least of which is how efficient (sensitive) your speakers are. The folks who designed the loudness contour circuit in your amp or receiver can't have that exact information! That's the fundamental problem with the "fixed" loudness circuits.
Spot on with that -- pretty much how I use the one on my Mac as well. Makes a big difference at night, when the volume is low. Couple of watts and my speakers are barely breathing -- the variable loudness control works really well to give them a bit more life. :thmbsp:
Spot on with that -- pretty much how I use mine as well. Makes a big difference at night, when the volume is low. Couple of watts and my speakers are barely breathing -- the variable loudness control works really well to give them a bit more life. :thmbsp:
Thats exactly how I use mine, same situation.Late night listening is done exclusively on my cr620.:thmbsp:
I couldn't live without the variable loudness control on my Yamaha CX-1000U. Loudness buttons on other gear I've heard work ok short term, but I find that I end up with more listening fatigue that way (not to mention the risk of a blown tweeter). On the CX-1000U I can find a perfect balance on any record at any volume level and I haven't heard any coloration or noise added to the signal.
Writing from personal experience, the loudness button on my Marantz 2238 is quite the blunt instrument and makes me fear for my tweeters. I do not like the sound either - too boomy. I eschew using it.
I keep my Yamaha CR 620 on "flat" since that is for work listening. On the Yamaha loudness knob, "flat" is designed for low-level listening.
My main system amp and line stage have no tone controls at all, so I don't have the "loudness" option.
Exactly! One reason I mentioned the Yammy method is that the loudness control can basically be used as a volume control because unlike my C504, turning CCW from flat cuts the mid-range instead of my case where turning CW from flat causes a boost in the bass and highs. I kinda prefer the Yam, but no biggie.
