I've picked up two low budget modern receivers off eBay for under $100 each.
In this corner:
Integra DTM-5.3 circa 2005ish
In the other corner:
Marantz SR4021 circa 2009
Integra has 2x 10,000uf main caps, Marantz has 2x 8,200 uf main caps.
In this corner:
SPECIFICATIONS
AMPLIFIER SECTION
Continous average power output (FTC): 100 W per channel min. RMS at 8 ohms, both channels driven from 20 Hz to 20 kHz, with no more than 0.08% total harmonic distortion.
Dynamic power output:
2 x 170 Watts at 2 ohms
2 x 135 Watts at 4 ohms
2 x 140 Watts at 8 ohms
Total harmonic distortion: 0.08% at rated power
Frequency Response: 20 Hz to 30 kHz; ±1 dB
Signal-to-noise ratio: 100 dB (IHF A. 0.5 V input)
IM Distortion: 0.08% at rated power
Damping Factor: 60 at 8 ohms
Dimensions (W x H x D): 17-1/8" x 5-7/8" x 13-7/16"
435 x 150 x 341 mm
Weight: 19.8 lbs. (9.0 kg)
AUDIO SECTION
80 wpc 20hz - 20khz 8 ohm
100 wpc 20hz - 20khz 6 ohm
THD (0Hz - 20kHz, 8 ohm.) < 0.08%
Frequency Response (+/- 3 dB)
S/N Ratio
