Low down on Kimber Pbj as a phono interconnect
wapfunz
WapfuNZ
Been reading some conflicting ideas about the use of Kimber Kable PBJ as a interconnect between the tonearm wiring and phono preamp. I was thinking of using it with my Jelco SH370H. Terminating the tonearm wiring and then using the kimber to the phono stage. Any comments. :tears:
If I remember correctly, the PBJ is not shielded. Just to be safe, I'd go with a shielded cable in that applications.
I tried a PBJ on my Dual 1229. I had problems. I swapped it over to my CD player and used the rocketfisk that was on my cd player. All was good.
I had them too, and had hum problems with the CJ equipment I was using at the
time. switch to Straight wire and no more hum, It's great wire but it depends on your
equipment that you have.
