My analog setup, as currently configured does not hum, not even in the slightest. It also sounds pretty damn good
I bought my Grado in the low output Sonata variation (mine is a 1.5mV) on the recommendation of my dealer. I was interested in a regular Platinum, but he was pretty adament that I go low output when he discovered it would be going on an A.C. Pro-ject. He is a big Linn Soundek fan, and a Rega Dealer, but also loves the Grado sound. He also hates hum and noise almost as much as I do. His personally prefered way of getting around the Grado hum issue is going with the low output models, and he advised I try the same. Further research \i conducted revealed that Grado originally developed the 1.5mV models to go on VPI tables, due to hum issues; in other words, my dealer's story checked out.
Taking his suggestion to heart, I had mount one on my tonearm, and I tried it in his store on his demo rig, and it was dead silent, and sounded fantastic (he positioned the table on shelf near the floor, insight on the implications of this later). I was impressed enough that I took it home for an in-house audition, and it was
nearly silent and hum free, I liked it, and I felt I could live with the negligible amount of hum present at high volume, so I bought it.
About a month later, that negligible amount of hum started to grate on me, so I set about to correct it. Long story short, the A/C motor had nothing to do with it, but RF inteference generated by the transformers and other electronics in my McIntosh did, and an improperly matched phono stage with too low a gain, which forced me to lean on my preamp for volume, only made matters worse.
After some experimentation showed that that placement of my TT was my main problem, I got my table away from my amplifier. I also finally broke down and purchased a suitable phono stage; now things are rosey, my table is silent, and I do mean dead silent, no hum, even if you crank on it, nothing. Sounds nice too :yes:.
A picture is worth a thousand words (even a bad picture of an unkempt listening room/bedroom as it may be in this case:scratch2
. Once I moved my table away from the amp (where the NG is now) and drove it with my Monolithic, things got truly silent.
One thing to note in the Phonostage department. These low-output Grados are an odd duck in that they need high gain, and 47Kohm loading to sound their best, and they are a good enough cart to be held back by your run of the mill integrated phono stages. Be prepared to spend some dough on a suitable phonostage, and you will be rewarded with great clean sound.
Let me know if this helps, or if there is anything else you would like to know.
