You might want to google "Kef 107 power requirements" to view their owners manual and read to read page 9 carefully.
Risk? No, unless you're foolish enough to run the amp at maximum volume. And maybe not even then but the distortion level would likely make that unlistenable anyway.Hey guys, is there any risk driving a pair of big KEFs 107 with a low watt tube amp, namely the 8 W/channel Musical Paradise MP-301 MK3?
I have read in the manual where it talks about amplifier requirements. It says that they will perform optimally when driven with 300 W/channel, but due to their high sensitivity (90 dB) they will be just fine with as little as 50 W/channel. I don't know how this would translate for a tube amp....
Will it work well and sound good in your particular situation? Try it and see.
I can't imagine that unnoticeable distortion would cause any problems. Distortion from SS amps is much more destructive than distortion from tube amps.By "risk" I'm referring to some possible distortions that I wont notice but that can damage the tweeters, especially on long-term
