I have GPA 604s that I run with 1.75 watts. A 45 amp. Absolutely no problem with headroom. I have tried many different amps including up to Conrad Johnson LPS70 (70 watts) and others in between and my 45 amp works best imo...
FYI- I have a 2A3 integrated Bowei chinese amp that is very nice and is definitely enough power (supposedly puts out 8 watts, not sure how... but sounds like it) and I have another 2A3/45 amp that does a great job also. I would consider selling either and both within OP's budget. Pm me for info if any interest.
I've found at that efficiency 4w is plenty.100db? You need more that 4w to have any headroom.
Perhaps I don't listen as loud as some![]()
I have limited experience in this observation.4 watts with 100dB speakers, is the same output level as 40 watts with 90dB speakers.
That's about bare minimum for a large living room, IME.
Regards,
Gordon.
Thanks, guys. I just needed those three magic. Words: single ended triode. I’ve read a few articles on them, and this is definitely the route I’m interested in.
I think you're making a big mistake based on a fundamental misunderstanding. You seem to be assuming that because the volume control is very low down you're not using much power. That isn't necessarily true. A 40W amp could be putting out 1W with the volume control on 1/10. A different 40W amp could be putting out 40W with the volume control on 1/10. The position of the volume control really tells you nothing about the power output.I currently run an integrated 40 watt/ch tube amp with 102db speakers and I hardly ever have the volume above two or three.
Correct. A very high input sensitivity means you'll get XdB SPL with the volume control very low. A very low input sensitivity means you'll get the same XdB SPL with the volume control turned up high. That's input sensitivity, not available power output.You’re saying If 3/10 is unlistenably loud it doesn’t necessarily mean I have too much power?
Well, I use a Decware amp with 100dB speakers and while it does produce excellent sound and surprisingly high volumes in a small room, I do find it sounds better at lower volumes and gradually lower quality sound as the volume goes up and the complexity of sound increases.With 100db speakers you'll never use more than a fraction of that first watt. Here's a good read and I'd certainly consider Steve's Zen triode amp.
http://www.decware.com/paper43.htm
For listening to a large orchestral work with a lot of dynamics at a healthy volume, the Decware amp can do it but it loses the detail and magic it has at lower levels
In short, for me it's not enough for all types of listening, and I like having other amp options with more power. For listening to a large orchestral work with a lot of dynamics at a healthy volume, the Decware amp can do it but it loses the detail and magic it has at lower levels and my PP amps sound better.
