My Amplitrex tube tester won't test them either. Could probably get the vendor to send the test parameters, but not sure it is even worth messing with since uses for 6X8 are so limited. The other tubes in the organ all tested good, so would guess these 6X8s are good too.ive salvaged a few bladwin organs, 30-something 6SN7 on the tone board. ive never come across or seen this one before.
ah, bummerMy Amplitrex tube tester won't test them either. Could probably get the vendor to send the test parameters, but not sure it is even worth messing with since uses for 6X8 are so limited. The other tubes in the organ all tested good, so would guess these 6X8s are good too.
Are the 12ax7 baldwin with green lettering if so, are they 17mm long plates or 13-14 mm short black plate tube. if there short black plate set them carefully aside for testing surprising great sound from them short black plate if green lettering there most likely Sylvania a great sounding short plate..also with a tipped D getter on top the short plates...wonderfull 12ax7 tubes.Am going to pick up this freebie this afternoon. Have seen pics, but can't tell what tubes are in the tone board sections. Bunch of them though. Anyone know what tube number these might be? Baldwin used 12AU7 and 12AX7 typically, but I've read these might be some 6XXX type tube.
