LS360,CS350, F113's layout
Avidfan
Banned
Should the subs (F113's) be pulled out ahead of the front main LS360's, or even with, or behind the LS360 mains?
Should the mains be even with the CS 350 center?
Speaker placement suggestions would help.
Thanks
My screen is (circa) 9 feet long.
Room 20x20
Thanks
Room 20x20
You have flexibility with the F113s, use the phase adjustment and polarity to get them to fire in phase with the speakers. Whether they are in line, behind or in front of the speakers, play test tones near the crossover frequency and adjust the phase and polarity until you have fuller sounding bass (in phase with speakers). After that, adjust the levels and ELF trim to get a flat response below crossover frequency.
Your center channel should be in line with the L&R speakers if possible.
