Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Having a hard time finding where to lube my tonearm lifter.I have to carefully lower tonearm as it seems the grease is old and wore out.Tried the"tube" but absolutely no vids.
You have to remove cueing mechanism.
Clean old silicon oil completely.
Use new 300.000 or 500.000 cst silicon oil.
Do not use lots of oil, you have to use it on inner spring, when you fit the cueing lever back in, it will seal the oiled mecha.
