Thanks to member vinnysj, we have completed a PCB design for a replacement DML-01 using more modern components that should be available long enough to do a couple of runs. I ordered a test batch of boards and, while I am waiting, I turned my attention to designing a DML-02 PCB. The initial results are shown below. The 3D model shows too many pins. It is a 12 pin device where the pins are on 0.200 inch/2.54 mm centers so I used some 0.100 inch/2.54 mm headers for the visual design. I was able to get some dimensions for the length using some images of a replacement DML-02 and I took some measurements from an image to determine a width. It was really tight and my results didn't seem to match the images of the replacement DML. I don't have any DML-02 modules or equipment that uses them so I can't make a direct measurement. If someone has access to a DML-02 or a board that uses one, I would greatly appreciate a set of measurements. The most important measurement would be the pin-to-pin distance between the rows of pins, but any and all measurements would be appreciated. I've never done this before so I don't know if these things will work. I am going to test the DML-01 on my own equipment and I will be scouring the Internet for a dead piece of equipment that uses the DML-02 modules. If anyone has a lead on such a piece of equipment for a reasonable price, please let me know.
