Well, I measured a ~1.2V DC voltage drop across the IR LED (TLN104) which makes me think the LED is good. Soo. Hmm. Lost again.
(Although, this player was having the same issue and it was the counter - so maybe it's the sensor that's bad on mine, not the LED.)
So I should add an IR sensor to my parts list - problem is, I can't figure out what an available equivalent would be. The part # from the Luxman manual is TPS605.
Edit: All seems better (knock on wood) after I simply cleaned the LED and sensor with isopropyl alcohol on a q-tip. So I will leave that be until the new transistors & caps come in, and then cross your fingers that'll be it!
