Hi all wondering does anyone know the correct procedure to set the Luxman l-100 power supply voltage? I couldn’t find anything in the service manual or here on AK? Thanks for your help!
I never worked on L-100. You are measuring DC voltages on these pins so for each pin you should measure with respect to the chassis ground. You red probe on the pin and black probe on the chassis.
As I see in the SM, pins 7 & 8 supply the +ve rails and pins 9,10 -ve rails to the input stages of 2 power amps. Output stage rail voltages come directly from the filter caps.
I tried to measure the adjustment today and have zero volts at the first left pin 7, none of the relays click with or without the pre in-main out jumpers in. The protection light just flashes so far amp isn’t recapped I couldn’t find any transistor or diodes shorts so will keep looking to see what else could be stray to cause this
