Again assuming you tested the PRE-OUTs/MAIN-IN to verify a preamp issue.
Switches can't be ruled out, suggest trying TUNER, AUX-1, AUX-2, same
problem on these inputs? For each preamp switch, put gentle pressure on
the switch so as to slightly shift the switch mechanism, repeat a few times
then fully depress/activate that switch, repeat a few times, note any change
good or bad. That switch probably needs further cleaning.
Have another look at solder joints in preamp, make sure all good.
Tracking down distortion without a scope is a bit tricky. You could build an
audio probe. Use an old RCA cable, connect a probe/bit of wire with a point, and
a series film cap for dc blocking 0.1-1uf/400-600V(?), connect RCA into AUX of
another amp for playback. Probably need a GND wire between amp under test and
playback amp. Or you could buy something like this,
https://www.ebay.com.au/itm/154045484576
It is certainly a toy but is useful for binary yes/no audio testing, it does
struggle with low level signals
