Luxman L-100 missing foot
AusmanGray
Hey all, just picked up a Luxman L-100 and loving it. Didn’t know I could get this kind of clarity and warmth out of my system. I bought it from a kind neighbor who gave me a deal. Only issue is that one of the four metal isolation feet is missing. Front right.
Does anyone know the thread size and dimensions of the original feet? I’m having difficulty removing the other plates to get a good measurement and don’t want to damage anything. I want to either find an exact replacement or a matching aftermarket set of four. Any advice would be very welcome. Thanks!
Can you remove any of the other feet? If so, remove one and take it into a hardware store. Most would be happy to help you match up the correct size/thread type. From there, simply order a new set of 4, with the correct thread/length.
My C-1000 does not have the original metal feet so I can’t say what holds them in place. I do have a T-110 which has the metal feet but these are special with a second short foot under the main foot to allow close coupling to the C-1000/L-100 for aesthetic reasons. These longer feet are attached to the cabinet with a wood screw through the center. It is a 3mm diameter x 17mm from tip to underside of the head.
Shoot a pic of what you are up against and we can comment on what we see.
There are very nice rubber feet on Amazon, all kinds of sizes. Get a thread gauge (metric) and use that to find what screws you need.
