When the outputs go, they frequently take out upstream components. As jwalker said, check your outputs for shorts, then check the emitter resistors for opens, and the parts in the driver stage for problems. Tools to have are an multimeter with diode check function, screw driver, soldering equipment, service manual.
Good luck! Those are nice amps.
