I have this beautiful Luxman rig that I acquired from my brother but the amp (L-480) has an issue that is apparently common to these models. I did find the following that best describes the problem from Geoffrey Kolbe (May 6, 2008) on an other forum:
"There seems to be a problem with a particular transistor pair (2SA 949 and 2SC2229) in the power amplifier section which can lead to an intermittent fault. The transistors run very hot and as they age, one of them can break down intermittently, (probably Zener breakdown as the rail voltage is quite high at 53volts), changing the quiescent DC output voltage of the amplifier. The DC voltage should be zero, and a relay disconnects the speakers if the voltage rises to +/- 1 volt or so. The red light on the front panel starts to flash, (as it does at switch on as the voltages settle) Replacing the 2SA 949 and 2SC2229 transistors with a pair of transistors that can take a heat sink would be a good idea."
Would anyone one on AK experienced the same issue and if so, what did they do to remedy it or who could I contact to get the unit repaired?
Thanks!
