Nope just the US/North American model. My T-110s are T-110U models. Just Luxman's way. Pioneer had different letters for different models tooUniversal Voltage model? (Switchable voltage).![]()
The Thlot Pickens.made for the usa, but probably Switchable voltage - i have a luxman l-100u from same year and series, it has a Switchable voltage transformer.
Well we know the M-4000 is not multi-voltage.
Thanks for the pointer. I'll direct a question his way (and to the group).FWIW, Blue Shadow knows his Luxman gear and I appreciate the knowledge that he shares on this forum.
I hear (read) that you are the keeper of Luxman knowledge. I have this m-4000 that I am told shuts down after an hour of hard use. I haven't seen it happen yet but I do note the left heatsink is warmer than the right. I've seen bits and pieces of info posted on the bias and offset adjusments but nothing complete. At least not enough for me to move on it yet. Do you know of a procedure I could access? I've downloaded a few manuals but none have had the detail. Not lucky yet, I guess. Thanks.Nope just the US/North American model. My T-110s are T-110U models. Just Luxman's way. Pioneer had different letters for different models too
The manual I have shows the offset being tested at the speaker terminals and adjusted by the VR close to the center line of the amp on the PB-1018 driver board, the front board of the two back by the outputs. One board for each channel. The setting here is 0± very few milliVOLTS
The bias is set by measuring current through the fuse on the power board, PB-1019, rearmost board. Replace fuse with meter and set the VR on that same board to 100 milliAMPS through the fuse. This VR is centered on the power board.
Commonly these settings are done with the amp on, no signal, volume all the way down and adjust a couple times after the amp has been on for a few minutes. Check again after 20 minutes. Done.
I've been asked to repair a Luxman amp. (lucky me) The email I received listed it as a M-4000u. I can only find one reference to this model on the web and it is in a sales ad.
Is anyone familiar with this model? How does it differ from the M-4000 or M-4000a?
Thanks, Dave
Came across this older post regarding the Luxman M-4000u, unless the above poster was referring to a custom modification
he likely was confusing the XLR speaker outputs Luxman changed to in late in production.
This in response to wide spread displeasure with the awkward push terminals.
