Yes, the Island of lost toys indeed!
Thank you
@Skywatcher and
@Binkman! All of this is so helpful. I was truly surprised to find that bent wiper and the "chunk" or carbon missing-anyone ever seen anything like that? It's hard to imagine how that would happen unless someone had opened it up in the past. Even if it got dropped on its head at some point...
I'm not too concerned with the motorized part of the volume pot. I've been having a very hard time finding any 150k Ohm dual ganged pots out there from any manufacturer (nothing on Mouser or Digikey, eg.), motorized or not. Any leads?
The only one I did find I found thanks to a lead by
@milo63. I came across
this pot, which is very similar, though the loudness tap is a pin rather than on top. Would it work to just bend it back and solder it to the wire currently soldered to the loudness tap? Otherwise, the only dual-gang pots I could find had 100k or 200k resistance. I've been doing research, but it's still a bit out of my knowledge repertoire understanding how, in this amp, substituting one of those might affect performance.
I will take a very close look at the PS board, with the magnifier, looking for cold solder joints, corrosion, and glue. I'm afraid I'm away from home at the moment, so I will have to get back to you on the outcome of that, but would love to at least get the volume pot ordered and see what kinds of problems that solves.
@Binkman, to answer your question, I haven't done any recapping yet. Probably that's a necessity. What I'm thinking is to take this mystery one step at a time, so I know which things I'm doing are solving which problems. Since the pot is pretty obviously damaged, I'm thinking that is step one. Then I'll take a look at and reflow solder joints on the PS. If there's still volume issues and/or dc offset issues, I'll start measuring transistors values across the main pcbs. Luxman didn't make it easy to do any work on this thing without taking it all apart, even just for measuring. Not to mention that getting to most the back of the main pcbs is nearly impossible without either unsoldering the output transistors or removing them from the heatsink.
Thanks again, y'all. So grateful for your expertise.
