Starbender
Gathering dust...
I'm struggle with this beautiful receiver for a while. Fully recapped. It has tons of tantalum caps everywhere. All replaced with Nichicon low leakage UKL caps.
Sound of the receiver is improved after recap. But one problem remains; left channel has white noise, amplifies with volume control. If I connect efficient speakers, it becomes unbearable.
Tried different things to narrow it down. R-1500 does not have pre-power amp jumpers. I swapped power amp channels internally, hiss remains on the left channel. IMO, this indicates the problem probably lies within the pre-amp section (or power supply rails for preamp?).
3300uf 25v & 1500uf 50v caps connected to second winding of the transformer (red-brown-red).
Between these caps and the transformer there is two 2A fuses. Fuses connected to caps via 0.1uf film caps&1N4003 parallel diode. According to SM, this rail power up pre-amp and tuner sections. I decided to replace these diodes, because one of them measures strange. After diode replacement, 2A fuse connected to 1500uf caps negative leg smoked. Checked for shorts, nothing. Second attempt, fuse smoked again. According to SM rectifier diode cathode(parallel with 0.1uf cap) goes to capacitor.
What can cause problem like this. I'm sure diode replacement was correct, all surrounded parts and chassis isolated before power up.
Any idea?
Any idea?
