Luxman Relay Replacement
preacherJohn
I've been searching for a replacement relay for a Luxman L430. I suspected this relay was bad, and I hit it with 24v and it doesn't do anything. The original is marked VB24MC. 24vdc, TV3. I would really appreciate if someone could help me find one. I'll be making an order to either DigiKey or Mouser in a few days and would like to pick one of these up. Thanks bunches.
You will have to check the lead spacing and current specs, but this might work. Mouser is out of them right now but other distributors may have them.
Just checked Newark. They have them.
G4W-2212U-US-TV5-HP-DC24
Rob
Thanks Rob, will do. I was just looking around at DigiKey, and I've seen some General purpose, and a Panasonic. The measurements are close, but not exactly the same. I guess as long as I can get the leads to reach their spots in the board it would be OK.
