Luxman SQ-38u - tubes setting
david76cz
Hi, I have Luxman SQ-38u, but without the tubes installed. I can't find the tubes configuration anywhere. Please can anyone help me to figure out the position of each tube? Is it like in the picture?
2nd question is: What kind of tubes you have in your amp? (Mullard, Tung-Sol, Genalex, Electro-Harmonix, JJ, TAD, Sovtek, ...)
Thank you
David
Surprised this is not in the manual or the tube sockets are not marked as they are on my Luxman amps.
This site has a picture with the tubes identified:
Yes, I was also very surprised that it's not marked inside the amp nor described in the manual. :(
Thank you so much - this is what I was looking for.
I just bought my SQ38U last month
BTW, replace all those white caps with Jupiter beeswax copper, and the two 0.47uf 630VDC yellow caps with Mundorf Supreme (in the power supply) will take your amp to another two notches in SQ.
