Hello!
I'm new here, nice to meet you all.
I'm on a bit of a quest, and for the first time ever, ebay has failed me.
TL;DR: Does anyone know where I can purchase an LXI Series 9300 Amp, or of someone who can repair mine?
The long story:
I have an LXI Series 9300 stereo system, with all the options including the original standing speakers. I purchased it a couple years ago at a local thrift store.
I've been mainly using the turntable and the aux input.
Recently, when listening via the Aux input, both speakers made a loud crackle and went completely silent.
The system still had power, the graphical EQ still showed the audio movement, and all the other functions seemed to behave normally, simply no audio coming out of the speakers.
I tried swapping the speaker outputs to the B outputs, no results.
I took a look inside and couldn't find anything obviously wrong with the two amplifiers. Neither was showing signs of heat stress, burns or cracks. I saw one blue coax had some corrosion at the termination point which I cleaned. (seen below)
I took it to a local marine electronics repair shop (the only electronics repair within 200 miles) and they said that many of the caps had leaked fluid, causing the corrosion and likely the failure, and said it would require replacing all of the caps, and was something they wouldn't do (since they're marine oriented.) They said it would most likely be cheaper to purchase a replacement.
I took to ebay, but I can't find the 9300 model specifically. Only models above or below, and even then very few and I'm not positive that they're cross compatible with the 9300.
Does anyone know where I might find an LXI 9300 amp? Or know anyone who does repairs on amps like this, specifically with aged out capacitors?
Thank you for any help you can provide!
The long story:
