Where do I start? found this unit on the ground at a scrap yard, looked like one of the massive earth movers they use had partially run over the right side of it, this bent the right side frame in a V shape, bottom plate was penetrated by something sharp in the forward center position. front face plate however looked unscathed so i decided to take it and see what was what. Managed to get top cover off and bottom plate. The puncture had pierced the filter caps board and severed 5 or 6 traces, it also clipped and bent upward part of the center support plate that runs right to left and separates main filter cap board and amp board, this cracked amp board and 6 or 7 seven traces on that board. The power cord was intact but partially severed. Wish i had taken pics before i started but i didn't. looked salvageable, I decided to dig in. unit looked to me all original inside. Solder joints were terrible on most boards so i re-flowed everything. I found a 33uf cap up near the relays that had a lifted trace and was open so i replaced it, i also replaced the hazardous rifa cap where the power comes in. The 2 main filters were heavily damaged so i decided since it was tore apart i would just recap everything, all except the control board up front, to this point i have not touched it. I was able to reshape all the bent chassis pieces to near spec with a vice and hammer and brute strength. Repaired damaged power cord, double checked all my work and decided it was time to reassemble and see whats what. I had no variac at that time and had read all the dos and donts about DBT's and these things and decided i would be the guinea pig. IT DOESN'T WORK! Hooked up to the DBT i got exactly nothing, no light on unit or dbt, no noise of any kind, nothing! So i went strait to wall power, loud hum from tranny, protect light coming and going, then along the heat sink nearest the tranny a puff of smoke......maybe two. I checked all the fuses, none had blown, tried again and got nothing, checked fuse at rear, 15amp i think and this time it was blown. I looked in area where i saw smoke but nothing jumped out, turned it over and looked for bridges and such, found none but did find a couple joints that i missed that looked sketchy, touched them up replaced fuse and tried again, no hum from tranny this time but another puff of smoke from same area. I now have 3 blown a1106's outputs a 150 ohm resistor 3 .33 ohm emitter resistors as well as a .68ohm emitter resistor and a 82 ohm resistor. I could find no other components around there that were bad. Looking at my work on main caps board today I found one broken trace i had missed, could this be the problem? I will attach some pics of where im at now. I cant seem to find these ceramic emitter resistors in stock anywhere, are there other options? I know this is lengthy and my troubleshooting is haphazard but i paid nothing for this other than the caps. I also got a variac for Xmas. Any assistance would be greatly appreciated
