M-70 vs p2200
mr_RBG
Well-Known Member
Probably it is too soon, but hope I will be able to fix my M-70(post below).
I have Infinity Kappa 8.1 speakers and it looks like they are not so powersucking speakers as K8, however, people say that they benefit from POWER :). I found Yamaha p2200 amp locally and I wonder if it would be better than M-70 for my kappa's?
The P2200 should be a more robust amp given that it's a pro audio model. Whether or not that translates into noticeably better sound or performance I don't know.
Thanks! Do you think it is a good idea to bi-amp Kappas with p2200 on the bottom and M-70 in the top?
A word of caution. I don't believe the P2200 has built in speaker protection.
I think trying a bi-amp setup with those two amps is worthwhile.
Although a 2200 is well thought of, I would stick with the M70.
It's a good, solid, good sounding, pretty, and well protected amp. Replace the X cap on the power input board, NOW. It WILL smoke.
The rated power difference between the two is negligable.
