That's what I thought. I just got recently a damaged Yamaha M-70 and managed to fix it. Without the manual I didn't know how this amp operates.
So I turned it on, Protection went on and R966 went in flames (220R - flame proofed resistor, on the pre-drive board) since the previous owner didn't reassemble the heatsink support bar (the metal that holds the pre-drive board in place). What happened was, this metal bar scratched the pcb and made contact on the ground, feeding voltage where ever it went and fried R966, lol.
I checked everything and replaced R966 and went thru all the necessary checks stated on the service manual and everything is fine. And yes, Protection lamp does turn off around 5-10secs.
However...when I set the DC offset to 0V, it seems to move around 3mV to -3mV, back and forth. To those guys who has done this before, is this normal for this amp?
