I have an MA5100 that is very dear to me. 20 years ago I stumbled on a yard sale. They were using it to play music...... for the yard sale. I asked if they were selling it. They said yes. I asked how much. They said $15. And here we are. I adore it.
After two recent back-to-back negative repair experiences (with two different McIntosh authorized shops) trying to get it in tip-top shape, it began acting up again.
I was ready to through in the towel when by chance my troubleshooting took an interesting turn.
I hope some kind soul can help me weed through my findings. All things now point to grounding -- at a minimum -- either outside the unit or inside the unit, or some combination of both.
===== INITIAL SYMPTOMS ====
It began as a hiss, not quite broadband, in the right speaker only.
Over days the hiss got louder, and eventually it would produce these bursts/pops like static discharge.
Over more days, the level and bandwidth of the hiss grew more, and it just became unusable at any volume.
===== TROUBLESHOOTING =====
* Speakers/drivers: OK
* Input source, eq pots, filter switches, etc.: NO CHANGE/NO EFFECT
* Signal paths before the amplifier stage: OK (RCA ins and outs clean);
* Pots, rotary switches, rocker switches (recently serviced): OK
* Unplugged all signal inputs and outputs (only speakers and power connected): NO CHANGE
* Unplugged all other AC devices that share the residential electrical circuit: NO CHANGE
* Unplugged wireless devices in the home (router, chromecasts, etc.): NO CHANGE
* Changed to a different AC circuit: NO CHANGE
===== LUCKY STRIKE??? ======
Today things got interesting.
It occurred to me than some kind of RF interference from a device outside the home could be at play.
Why not: I grabbed a sheet of common kitchen aluminum foil and laid it on top of the unit.
This produced light crackles and pops as I ran my hand over the foil. All of a sudden:
**** THE RIGHT CHANNEL ISSUE WENT AWAY COMPLETELY.****
I couldn't believe it. Even idling hiss from both speakers seemed better than I could remember.
===== THE PLOT THICKENS =====
A few hours of listening enjoyment later, I revisited the foil, wanting to recreate the problem and solution.
Turns out the light crackles and pops were not from the interaction of the Mac and the foil, or from shielding it in some way: I hadn't noticed that the foil had draped over the side and would occasionally lightly graze the chassis of a Furman power conditioner that sits next to it. This interaction is what made the right speaker issue go away.
====== OUTLET CHECKS =======
Out came the circuit checker and multimeter.
Outlets on the Fuman:
OPEN GROUND (Neutral to hot: 118; hot to ground: over 60; neutral to ground: under 60).
Wall outlet:
OPEN GROUND
Next wall outlet (same circuit):
OPEN GROUND
3rd wall outlet (same circuit):
CORRECT (neutral to hot: 118; hot to ground: 118; neutral to ground: 0)
====== MOVE TO THE GROUNDED OUTLET ======
I moved the Furman and Mac to the good circuit and powered up. So far so good.
I fiddled with the foil again, and on first contact grazing the chassis of each: the circuit tripped.
===== WHERE TO GO FROM HERE ??? =====
Obviously the outlet grounding needs to be corrected (I'll speak to the landlord).
The big question: what might be wrong on the Mac side?
A loose connection somewhere leftover from the recent repairs?
A failing component?
I'd love to have a look, but it's not my strong suit and don't know where to start. In my current situation, a third visit to a repair shop won't be in the cards for some time.
Thanks for reading. Will appreciate anything you can impart.
Wall outlet:
OPEN GROUND
OPEN GROUND
