MAC 1700 Can Replacement
RobertInc
Hello Robertinc
1) did you tryed to see if original replacement is available at factory before to buy non adapted component ?
2) 4000µF/50V is not a complicate value
3) do you have the right service manual for YOUR unit with the right serial number ?
4) is your unit working before to touch anything inside ?
Welcome on AK
Hey Clinic-audio, thanks for all the great help!
1. Yes, I looked for GE 066-112 cans first and I have no luck
2. 4000µF/50V is what's listed in my manual, are you saying the part I linked to is not a match? I wasn't sure and thought best to ask here.
3. I have all the original paperwork with the schematics. I assume it matches the serial number, but I'm not 100%. The unit is 29J50, I believe it's a very early model.
4. Yes, the unit works. I've cleaned it with a can of CRC QD and then hit all the pots with Deoxit5. I worked the front switches pretty good and everything seems to work well. I didn't keep the unit on for more than a few minutes. I wanted to get all new caps in there. Any advice here? I was using the above resource, which has a list of caps to order in an excel sheet. I was just going on that. Thanks so much for your help with this! I
