jd3rdcoast
Hi All;
MAC-1700 S/N 37J4, No Output Monitor board.
I am just about finished with this MAC-1700 but have an issue I would like some input from the experts.
I had another thread regarding initial issues that were cleared up with replacement of some burnt resistors, Recap of P/S, PreAmp & Driver boards. Here is Link to my other post:MAC 1700 w/a power Supply issues.
My current and hopefully final issue is in Tuner mode, I am getting very large distortion from the output of both sets of differential pairs Q20-Q24 to Q25/Q26 bases. Also the outputs heat up quite hot which I believe is attributed to the distortion or excessive signal level when Tuner is used. I have scoped the Tuner input to the Driver board and it is clean although very robust levels with mild volume.
Distortion shows up on both channels equally. Of note: The Tuner signal is exponentially higher than the other inputs (AUX/Phono). The distortion sets in at about 18 W of output and Vol pot is only at about the 9:00 position. I have tested the Amp with 1Khz sine wave via AUX input and it is good up to about 55 Watts output before clipping w/Vol at about 75%.
Question:
#1. Is the high Tuner signal level over driving the Differential Pair compared to other inputs or are they just no longer up to the task? I have KSA992 sets I can match up here but wanted to see if anyone had another take on this. Edit: I just re-read Hints & Kinks thread stating all units should have Diff Pair changed out. I noticed mine has a mix of 2N4249 and 740's factory installed on both sides. I'll match 2 sets of KSA992's and get them installed.
#2. Is the Tuner signal normally so much higher signal since coming from a Tube based circuit. Or is it in need of professional alignment?
Here is pic of Diff Pair output from Tuner. Scope at 2v/div.
Power Output Schematic - Left Side:
Question:
