I was given a MAC 1700 and am in the process of getting it back on the road again. One of its output transistors had suffered either a bond wire or die attach failure, so it could only muster about 500mW before flat-topping the output. I replaced all four output transistors with MJ15003s and after setting the bias, the power stage works fine. And I replaced the electrolytics on the preamp and power driver boards. One was leaky and causing DC offset at the speaker terminal. The rest of the silicon and the main PSU caps all test fine. I checked the frequency response and found that there was a huge LF rolloff. I traced that to bad contacts in the Filter switch, which DeOxit fixed. I adjusted the bass and treble controls until the frequency response was as flat as I could get it, but it is still pretty lumpy. The following plot was normalized for 0 dBr at 1 kHz.
The plot was taken at the speaker terminals driving 1 watt into an 8 ohm load, and the Aux input was driven by the AP. The Filter and Loudness switches were off. Since both channels show the same response, I assume that it doesn't have any failed caps unless two caps happened to fail in the exact same way.
Is this response considered normal for this unit?
One interesting thing is that the 1700 uses mostly passive, high impedance tone controls. So the Audio Precision's 100K input impedance would load the circuitry and make any readings invalid. The MAC user manual is careful to stipulate the use of a VTVM when making measurements, so I use an HP 400E (10 Meg input impedance) to first buffer the signal before sending the signal on to the AP via the 400E's AC output connector. Using that setup, I see the exact same response curve at the preamp output.
Has anyone here done a deep dive into the 1700? I suppose I should simulate the original circuit to see what that shows.
BTW, disregard the comment at the top of the plot. It pertains to a prior test and had not yet been updated prior to this screen capture.
