rczetli
Hello! I am a relatively new member of AudioKarma and I need some help from the experts.
I recently purchased a MAC 1700 receiver with a blown output stage. All 4 output transistors tested bad and several base to emitter resistors were fried. I am going to completely rebuild both output stages and do some work on the power supply to start but I have a few questions for the Mac gurus here. The output transistors are part number: 132-070 and they cross to a 2N5303. I believe I read on this group that an MJ15003 would work well and is readily available. Is this correct?
There are also diodes on each of the output transistors marked part #: 070-031 and they cross to a 1N4820. They test ok but two of them are badly charred from the fire after the failure. Do you know what these would cross to in current production diodes?
I was thinking about replacing the diodes in the main power supply bridge. They are part number 070-041 and cross to Westinghouse 398B. I can not find any specs on the Westinghouse diodes. Does anyone know what a good replacement would be? Would any of the fast recovery diodes benefit this older design?
Finally, any other suggestions from anyone experienced with the 1700? It appears most of the coupling caps in the signal path are Mylar so for now I don’t plan on replacing them. I will probably replace the few ceramics caps that are on the driver board and preamp boards. Power supply caps test ok and according to the shop that was using this receiver there was no hum at all before failure but I may replace them anyway considering their age.
Thanks in advance for your input and assistance!
